Saltar al contenido principal
Why does my washing machine pause early in it's cycle?
My Samsung washing machine pauses a few minutes in to cycle once water is dispensed into the drum. I've experienced the uneven laod issues towards the end of a cycle and it's not that. Followed a load of trouble shooting. Waste is clear, filter is clear, water inlet is clean. Its as if it won't spin once the weight of the water is in the drum. I can sometimes get it to complete a drain and spin cycle when empty. I've also run a recalibration. Samsung have been beyond unhelpful as its out of warranty. Tried a local independent engineer but he was old school and couldn't give any insight. Any help/suggestions would be greatly appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hi @geraintstone,
Are there any codes being displayed when this occurs?
- de
No error codes, just freezes, then pauses before turning off. Turn it back on and is in pause status. I ran the diagnostic cycle and had an error during the high speed spin check. I think the code was 3c2. Any advice for this? Thanks in advance
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@geraintstone
According to the service manual there's no 3c2 code.
There is a 3C code (see p.37) although there seems to be some confusion in the manual as to whether it is a 3C or 3E code as there's no mention of a 3C code in the code table (see p.33) but 3E is mentioned in the explanation of a "3C" code on p,37.
Perhaps worth looking at all the same as it does seem relevant to the problem.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Geraint Stone estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 66
