Antenna Causing XBox Series X/S Controller to Not Work(?)
My Xbox Series X/S controller stopped working and has a weird coil whine when connected with a USB cable. After taking it apart I found that when I disconnect one of the antenna (see Image below), the controller comes back to life, and stops working when I reconnect the antenna cable. Is there a way I can fix the antenna and get the wireless functionality back? Currently I can only use the controller wired. Provided image is the antenna connection that is causing the problem.
Es esta una buena pregunta?
1 comentario
I had the same problem I plugged it in and used a small screwdriver to move the part the antenna connects to until the wine stopped and it fixed the problem for me
- de Micky Duncan
