Why is my pc slow?
It's very slow in literally everything.
Es esta una buena pregunta?
I have a friend who has the same issue and he told me it has to do with his RAM. Try replacing your RAM. Another issue would be if your pc overheats
Fue útil esta respuesta?
It could be due to many factors: insufficient ram (this laptop only supports max at 8GB which is the minimum requirement for ram configuration in 2025), a newer version of window could possibly slow the laptop dramatically because of incompatibility. Other factor could make this laptop model slow include heat and hardware limitations (CPU and GPU are not up to date standard). Make sure to double check some of the problem above on your laptop to find out which problem you may have.
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 16
