Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 20 Ver todo
Bluetooth lost range after battery replacement
I just changed out my battery using a kit I bought here at iFixit. It was a bit of a struggle but I got it done. However, now when I connect it to my Bluetooth speaker it starts breaking up if it moves more than like a foot away. I think the wifi is affected too but it's hard to tell (my wifi isn't great normally). I'm a little worried I might have broken something. Should I go back in and replace the antenna or are there other troubleshooting things I should do first before I open the phone again?
Note: I have performed several hard resets but the problem seems to come back in different ways. I think it is a problem with the range of the antenna.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
You’ve bumped off or damaged the WiFi and Bluetooth antenna, which is that s shaped cable right above the battery.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I opened it up again and that is exactly what happened. It got caught under the battery and snapped when I was putting the battery in. Always look twice before shoving something in everyone!
- de
Añadir tu respuesta
Pat estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 18
