Changing the language the computer was programmed in
The computer was programmed in Spanish how do I change it to English?
Es esta una buena pregunta?
Go under the Apple in the upper left hand corner to System Preferences > Language and Text. Drag English to the top position. You may also need to check in the lower right of that box for ": order for sorted lists".
Fue útil esta respuesta?
Hello Nichol,
You will have to re-install the operating system. Normally, the OS is based off the OS Installer disc, and cannot be changed without re-formatting the computer.
Regards,
-- Morris
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 716
