Saltar al contenido principal
Sucesor del popular Samsung WB150F, el WB250F enfatiza las capacidades de compartir con Direct Link y Smart Camera App de Samsung.
Preguntas 15 Ver todo
Screen won’t turn on
my camera can turn on as normal and even the touchscreen works but the screen stays black.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@john81163 if there is no menu showing or anything then it is most likely the LCD screen itself. It is possible that this is a backlight issue, so darken the room and turn the camera on. Now use a flashlight and angle the light at the screen on different areas. See if you can make out the cameras menu. If you do, then it is possible that this is a bad backlight . If not, I would proceed to replace the screen.
Since iFixit doesn't yet have a guide for this, use something like this video or even this one for the replacement.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
John estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 28
