Saltar al contenido principal
El ¨PSP 3000¨ fue lanzado en los Estados Unidos, el 15 de Octubre de 2008.
Preguntas 20 Ver todo
Why does my psp 3004 feel like its brain dead?
so after 3 years i found my psp that i remember that it had an inflated battery that i had removed and never used the psp ever since.But now that i have found it it feels like its become brain dead.What i mean is that when i plug it via its original charging cable and from the usb port it dose nothing and even when i plug it in my computer it doesn't show up.
someone explain cus i have no idea what's wrong with it ;(
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
also i just checked that there might be smt wrong with the files cus i tried putting the memory stick in an adapter and its not opening
maybe idk
- de
just learned that i cant access any files if i dont chose it from the psp WHEN ITS OPEN but still its not working
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi!
Okay, so what is the problem at the moment? Did the PSP failed charging and won’t do anything? Or does the USB failed?
First of all, do you have a new battery? If not, this is probably the first thing you need. When you did bought a new one, and it won’t show the orange light when you have the charger in, return it and get yourself a new one. If this also failed, then you might want to check the charger it self or the charge plug inside the PSP.
Is the PSP modded by any chance?
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
satos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 11
Todo El Tiempo: 34
