Saltar al contenido principal
The 8BitDo Ultimate Wired Controller was released in 2022 and is compatible with Xbox Series X, Xbox Series S, Xbox One, Windows 10 & Windows 11. This controller comes with 4 sets of internal vibration motors and two back buttons.
Any idea where to source replacement analog sticks?
Mine got stepped on i guess? because the stick doesn't return to center anymore
Mine is the Ultimate Wireless, but it should be the same stick?
I contacted 8bitdo with the following response:
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Replacing the analog sticks on the 8BitDo Ultimate Wireless Controller can be tricky because the manufacturer states that the sticks are not removable or replaceable. This means there are no official replacement parts available.
Possible options:
  1. Replacement rubber joystick caps:
    While the internal sticks themselves aren't replaceable, 8BitDo offers replacement rubber caps for the joysticks. They sell a set of two caps for about $2.99 USD, compatible with the Ultimate 2.4g and Ultimate Wired controllers. However, these may not fit the Hall Effect models like the Ultimate 3-Mode.
  2. Third-party parts:
    Some users have tried using analog sticks from other controllers as replacements, but this usually requires technical skill and isn’t guaranteed to work.
  3. Contact 8BitDo support:
    Since official replacements aren’t available, it’s worth contacting 8BitDo directly for advice or possible solutions.
Alternatives:
If none of the above work, you might consider replacing the controller entirely. The 8BitDo Ultimate 2C is a popular and well-reviewed alternative, priced around €29.89 on Amazon.nl.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jamie Pate estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 38
Ultimos 30 días: 134
Todo El Tiempo: 601
