Saltar al contenido principal
{A1989 / EMC3214}-Lanzado en Julio de 2008, el MacBook Pro de 13 pulgadas cuenta con el procesador Quad-Core i5 e i7 y gráficos integrados Intel Iris Plus.
MacBook Pro a1989 how to fix ripped capacitor
How I can recover my motherboard thx for help anyway
Update (12/29/24)
I cant even put wick on it 😔
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Sounds like the iron is not hot enough. You may need a new tip and make sure the tip is fully wetted with solder. When working some boards the copper traces sap away the heat. I often find I need a hot air rework station as well as a fair amount of foil to protect the other stuff from too much heat.
I’ll need to dig out my schematics and board view drawings to ID the SMD you’ve identified. I’ll catch you tomorrow with an update. In the meantime get some isopropyl alcohol to clean up the board a bit.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Oh ok that's putted a new light Excellent thank you so much!
- de
Añadir tu respuesta
Damian Kaminski estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 119
