How can I disable the PIN lock screen Motorola xoom?
I have Android 4.0.3 on my Motorola XOOM. When I enter to the security menu I can not get access to the "no".
Es esta una buena pregunta?
By setting up a PIN for your Motorola Xoom was it under the encryption choice by chance? If so you cannot unencrypt your xoom unless you do a factory data reset.
Or was it a SIM card lock?
If it's a SIM card lock, simply go to settings> location & security> set up sim card lock> uncheck the box to remove the sim card lock.
If it's under the encryption, however, go to settings> Privacy> back up my data (if you haven't done so already)> factory data reset.
Fue útil esta respuesta?
If will I make "factory data reset" installed applications will be lost or saved?
There's applications you can find for free or purchase that will back up all of your installed applications, Titanium being one of the popular sorts with the pro features that will aid you in reinstalling all of your apps after a factory data reset. However, one common issue to be aware of is that transferring large amounts of data have had issues so when resintalling I would move small amounts at a time.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 2,398
1 comentario
- de unrdp
