Saltar al contenido principal
Modelo A1059 o A1099 / disco duro de 20, 40 o 60 GB / rueda de clic sensible al tacto
What happes when you unplug an iPod during sync?
It was unplugged while syncing a podcast and now it will not power up and it is not recognized by windows or itunes
Es esta una buena pregunta?
Puntuación 2
1 comentario
I unplugged my iPod now it won't power up or be recognised by my MacBook, how can i fix this?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Drew, you may have some issues with the firmware. Anyhow, try to reset your iPod:"1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power. from here
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
Drew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 3,260
