Saltar al contenido principal
El nuevo formato de la línea 14 de Apple cuenta con un OLED de 6,7 pulgadas -como el Pro Max- pero con las mismas características que el iPhone 14, con una configuración de doble cámara y el chip Bionic A15 con una GPU de 5 núcleos.
Preguntas 20 Ver todo
iPhone 14 plus reboot randomly
Hello everyone, I'm posting a message here because my phone (iphone 14 plus) crashes and restarts by itself, I have the crash report, I need you to try to solve the problem, it's been like this for a month now, it's driving me crazy, I've switched back to the iphone 8 plus just long enough to understand, so if anyone has a solution I'll take it! https://pastecode.io/s/qoixm17c
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Your iPhone may have a damaged battery, or it has a damaged. internal part. Maybe iOS itself is corrupted and needs to be restored, if that's the case then you will need to restore the phone using iTunes.
- de
Agregar un comentario
1 Respuesta
I had similar issue, was under Apple Care, they rebuilt the entire phone. At a service center, it was great till Apple care ended, a few months.
Back to the same issue, random reboots and now randomly heats up.
Tried:
Removed protective case.
Turned off all background apps
Turned off app updates/refresh.
Deleted apps.
Do not carry in my pocket.
Bought a new Apple Charger/cord.
Do not use the induction charger any longer.
All this helped but still have the issue it is all random.
Do not expect a lot of help from Apple.
Irony, I traded up from I phone 11 with no issues, to the 14 plus, that was great for a few months.
Good luck!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Matheo Maufroy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 26
