Wifi reduced after screen replacement
I just recently replaced my screen and digitized an back screen panel as well and after wards my wifi signal has been greatly reduced. I have read posts and everything i've read relates to the metal panel with the 5 screws on the top of the back panel. The metal connector at the top post with the long screw is still there but yet i only get 1 wifi bar of signal. Are there any other parts of the phone that may need replacing to fix the signal issue.
thanks!
Update
So I cleaned all the parts and it works a tiny bit better. Te metal clip on the top part of the connectors is still there. But the screw goes in a little loose and I'm not sure why. When it's screwed all the way down not all of the metal is touching because the screw slips down when tight.
Es esta una buena pregunta?
