Saltar al contenido principal
La Nintendo DSi es la tercera versión de la línea Nintendo DS e hizo su debut en Japón a finales de 2008.
Preguntas 20 Ver todo
My DSI orange blinking light will not go away.
My Nintendo DSI has a orange blinking light (presumed because of dead battery) when i plug it in the light will blink normally. then, when i put the battery in the light will delay then blink faster when i have the pins connected to the battery. is there anything else i should look at before i get a multimeter and test the voltage on the F1 and F2. yes i have bought another battery and that doesn't work either.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi!
The orange light blinking is mostly caused by a faulty battery or that the battery didn't seat correctly.
F1 and F2 are fuses and you can try a continuity test on them to test if they are okay. They prevent the DSi from turning on if one of them are faulty.
I think this is related to the battery connector on the motherboard, as another battery failed too.
Can you share some pictures with us regarding the motherboard?
Thanks!
Fue útil esta respuesta?
Puntuación 2
This happens to me I haven’t fixed it when I try turn it on the blue light flashes for a second then all the lights turn of I took it apart because the top screen was only showing white now it doesn’t turn on can anyone help?
Puntuación 0
Añadir tu respuesta
math you estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 84
