bricked psp go no power, no charging lights.
I left my psp go uncharged for a time and when i turned it on, the screen for setting the time appeared but the console ran out of battery when i was adjusting the time. So it bricked. The charging lights dont work and the console wont turn on either.
How do i fix this?, i tried charging the battery by external means but nothing changed, i also saw a video of a guy that put his psp go to charge and instead of the battery had a little fan spinning connected to the battery terminals, apparently fixing the brick. But i have no idea if this will fix it. Any ideas?
Es esta una buena pregunta?
1 comentario
Ok i fixed it, the solution was to charge the battery with an external power supply. None of the things mentioned in the original post worked but this one.
After charging it for a while i plugged the battery, switched it on and it lighted up, now it doesn't have an issue with turning on. Solved.
- de pspfan2001
