Saltar al contenido principal
El nuevo formato de la línea 14 de Apple cuenta con un OLED de 6,7 pulgadas -como el Pro Max- pero con las mismas características que el iPhone 14, con una configuración de doble cámara y el chip Bionic A15 con una GPU de 5 núcleos.
Cellular Issue - unable to access cellular data
Water damaged, dried out by opening the back and front keeping in rice for 12 hours. Phone came back on. Old screen no display so put a new screen and the replacement works. Two Problems Cellular Issue (no bars no net) and Phone keeps restarting.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi,
It looks like water has affected the motherboard. iPhone 14 has a dual motherboard; the top board is for UI, and the bottom is for communications (network/cellular). Water ingress can affect the connecting layer and cause corrosion between the pins. This could be the reason why the iPhone is restarting and does not have cellular (baseband)
This is going to be a chip-level repair, and only a trained professional can perform such complex repairs. The boards will have to be separated, serviced, corroded parts replaced, and the boards reballed and refixed.
BR
Francis
CelMetro
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Arbin Shrestha estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 151
