Saltar al contenido principal
Información de reparación y desmontaje para el iPhone SE de segunda generación, anunciado y lanzado en abril de 2020.
Preguntas 20 Ver todo
IOS 18 Not turning on after battery replacement
my iphone se 2020 is at IOS 18 beta
i opened it and replaced the battery for a nohon battery with 2340mha
i used isopropyl alcohol 99.8% to remove the glue from the original glue
some got under the logical board but i waited for it to dry
  • after replaced i tested and everything was fine, everything working, i was using it for like 3/4 hours, np at all
  • then i waited for the battey to die to charge from 0% to 100%
but then the phone didn't turn on anymore, neither charging or pluged to itunes(windows version), tried put the orignal battery back, didn't work
forced restart doesn't work or dfu mode
my question is it a software or hardware problem? like the phone was perfect before the replacement battery die
what shoud i do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
See if it charges with magsafe. Maybe your charging port is defect or the cable is not plugged in all the way.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
brad estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 195
