How to replace the screen its brokin
How to change brokin screen
Es esta una buena pregunta?
@ahmedhaldo22325 that is a big challenge. I would suggest you check videos like this to remove your LCD. If you need to find a screen, that is even trickier because of the size. You do want to remove the back cover and then check the label on the back of the screen. Then use that number to try and locate a replacement. Most commonly replacement screens are more expensive as a new TV.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 16
