Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El controlador V2 viene en diferentes generaciones. Estás viendo a la Generación 4.
Button inputs mixing and matching
I was playing an online game and got so angry that I threw my favourite controller, 5 years old, on the floor full force. I regret it terribly.
I've opened her up many times to change worn out rubber padding. I opened her up again, saw nothing wrong except a broken metal weight on the lower left. Put her together. I use her on PC, so i checked the inputs and they were fine on windows. I check them in game and button inputs are mixing, I press SQUARE and the results with be SQUARE TRIANGE. Or I press R1 and Ill get R1, CIRCLE and CROSS output results. I suspect the green motherboard inside is faulty or needs a replacement? What do think?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
A broken metal part might have caused colateral damage to the PCB that would require careful inspection with a glass to find.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Athi Musoke estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 15
Todo El Tiempo: 128
