Mi telefono se mojo I la pantalla esta negra I solo bibra
no se como arreglarlo i creo que el problema es la pantalla
Es esta una buena pregunta?
Si es por caida al agua esta sulfatada o quemado el flex que une la pantalla con la placa hay que desmontarlo para revisar como esta te aconsejo acudir a un service de telefonia movil
Fue útil esta respuesta?
@gamingpro For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit does not yet have a guide for this, use something like this video to help you disassemble your phone. Remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the boards.
Take a close look at all components and connectors to assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@gamingpro Por ahora, debes dejar de intentar cargar, sincronizar o utilizar de cualquier otro modo tu teléfono. Esto puede empeorar potencialmente una mala situación. Esto puede dañar aún más tu teléfono.
El primer paso que yo daría es desmontar tu teléfono. Como iFixit aún no tiene una guía para esto, utiliza algo como este vídeo para ayudarte a desmontar el teléfono. Quita la placa principal y la placa de carga. Tendrás que retirar todos los escudos EMI. Si no retiras los escudos, no estarás limpiando las placas.
Examina detenidamente todos los componentes y conectores para evaluar los daños. Busca corrosión importante, evalúa las patillas de los conectores, etc,. Echa un vistazo a todos los conectores, así como a los extremos de los cables. . Una vez que hayas limpiado cualquier suciedad gruesa, utiliza alcohol isopropílico al 90%+ y limpia las piezas un poco más. Para una limpieza adecuada, utiliza [esta guía. Fue escrita para un iPhone 3G de Apple, pero todos los pasos siguen siendo pertinentes también para tu teléfono. No puedo insistir lo suficiente en la importancia de una buena limpieza, así que hazlo una y otra vez sustituyendo el alcohol después de cada limpieza.
Lo importante aquí es la limpieza. Por supuesto, lo mejor sería limpiarlo con ultrasonidos No olvides cambiar la batería. Es imprescindible y no una opción. Fallará si no te ocupas de ella ahora.
Después, vuelve a montar el teléfono y evalúalo de nuevo. Mientras no hayas limpiado la placa y sustituido la batería, todo son suposiciones. Ten en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si estuvo expuesto 2 segundos o 2 horas, lo que importa es dónde el agua (partículas) hizo el daño.
Mientras trabajas en tu teléfono, haz muchas fotos. Cuando hayas terminado, haz esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga un dispositivo con los mismos problemas que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 14
