Display flickering on the lap screen
Top side display flickering occurs
Es esta una buena pregunta?
@ashiljames connect an external monitor to check if that displays properly. If it does then you know the issue is either your display cable or your LCD. Since we can't see your display and going by your description alone, this sound like a bad LCD.
Use the HP Pavilion Gaming 15 Maintenance And Service Guide to work on your laptop. Page 49 shows you how to work on the display assembly. Check the display cable for any shaved wires near the area where it passes through the hinges etc.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 16
