Why the car is not starting?
I turn on the car. The engine try to start.car revs not moving and when I disconnect the battery and conect it again after 20 minutes the car start.
Es esta una buena pregunta?
MOST RELEVANT CAUSES👇
* An electrical short circuit inside the ignition switch may cause the engine to fail to start.
* Battery is a crucial component for starting a car, they provide power to the starter motor which then in turn starts the engine. Check the condition of the battery. BATTERY's ON AN AVERAGE LAST FOR ABOUT 4 YEARS, check when you bought it and then if its above 4 years, it might be just the time for the battery to get replaced.
* Electrical Issues:
* There can be many things under electrical issues, such as loose wires, corroded connectors, damaged fuses and worn wiring harnesses.
* Disconnecting and reconnecting the car battery reset's the car's computer alarm system, which might fix the "no start" issue of yours. Issues with the battery cable's connection can also prevent the car from starting, while a faulty car computer may be to blame.
* Fuel system problems include fuel line leaks, faulty valves, clogged filters, and bad gas tanks.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 15
