Why tv display is black?
The sound everything was fine by the display automatically went black but I can see light when turn of light in that room?
Es esta una buena pregunta?
@naseeha because of this “I can see light when turn of light in that room” youbalready know that this is a bad backlight. Philips is know to have trouble with the backlight strips failing. Replacing those on the inside of your display panel will fix you TV.
Of course, you can also check the power board and measure the voltage on your LED connectors but knowing the Philips TV it is most likely not the problem.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 47
Todo El Tiempo: 60
