After changing the charging ic, a problem appeared with the touch?
Can you help guys?? My iPhone 15 Pro Mix was damaged and I changed the charging ic and the phone worked, but touching it works for two minutes and then stops.
Es esta una buena pregunta?
I'm not clear on what it was you did; you've said you changed the charging IC and the charging cable. Did you actually do board level replacement of a BGA part, or did you just change out the lightning port assembly? Or are we just talking about replacing the USB-C charging cord? Which is it?
- de Jerry Wheeler
@dadibrokeit I changed the charging ic
- de خالد الصمدي
@khalid2021 Which version of the 15 pro Max is this? Is the US version? or the international version? (Does it have a SIM card slot?)
- de Alisha C
