Capture button isn't working for switch lite
Switch capture button isn't working
Es esta una buena pregunta?
Hi Maria!
What is already tried? Can you press the button or not at all?
Assuming that the Switch is up to date and that you've tried all the resets, the best thing to do is to clean the board on the left and to replace the rubber for the "capture" key. You only need to replace the rubber if you can't click it in properly.
Otherwise, you need to replace the board (left side daughterboard).
This the part you need: https://www.amazon.com/Motherboard-Mater...
Guide: Reemplazo del joystick izquierdo del Nintendo Switch Lite (till step 27, after replacing the board continue to assemble the Switch again).
Good luck!!
Fue útil esta respuesta?
All other buttons/joystick full work but capture button is only one not working. It is updated
Okay, if this is the case, then the board need a replacement. Button has a electronical defect…
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 34
