My meter does not work
My meter blinks -1 and if I touch probes together on continuity the blink stops but meter does nothing else.
Es esta una buena pregunta?
It would be worth testing the other functions on some references, IE:
will a 100 ome resistor measure at around 100 ome
will a 5v line measure at 5v
If other functions seem about right, you may only need to replace the buzzer inside the meter, so it will beep again.
You can also test if the buzzer gets any voltage if you have another meter to test with.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 21
