@leniniza it might help if we would know what they did to resolve your previous issue. If that is what made the camera stop, then we really would need that information.
For now, I would proceed like you would with any other camera repair. First make sure that you have all of your phones software update. Check in setting to see if there are any updates available. Next, try to use your camera in Safe mode. To enter safe mode
- Turn off the device.
- Press and hold Power button.
- Tap Restart.
- When the device is restarting, press the Volume Down and Power buttons simultaneously.
- When the device logo appears, release the Power button and continue to press the Volume Down.
- If you see Safe Mode in the lower-left corner after the device restart, Safe Mode is on, otherwise you need to repeat the process. from here
After entering the safe mode, the word "safe mode" will appear in the lower left corner of the phone screen. Now try your camera. If it works, you know that it is a third party app on your phone that causes this. You will have to delete those Apps one after the other.
If it still does not work, you may have to consider replacing the camera since it might be a hardware issue. Since iFixit does not yet have a guide for this, use something like this video. Replacement cameras are available at many online stores. Anything after that is a board level repair and you will need the schematics, component layout etc as well as test equipment to fix that.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@leniniza podría ayudarnos saber qué hicieron para resolver tu problema anterior. Si eso fue lo que hizo que la cámara se parara, entonces sí que necesitaríamos esa información.
Por ahora, yo procedería como lo harías con cualquier otra reparación de cámara. Primero asegúrate de que tienes todo el software del teléfono actualizado. Comprueba en ajustes si hay alguna actualización disponible. A continuación, intenta utilizar tu cámara en modo seguro. Para entrar en modo seguro
- Apaga el dispositivo.
- Mantén pulsado el botón Encendido.
- Pulsa Reiniciar.
- Cuando el dispositivo se esté reiniciando, pulsa simultáneamente los botones Bajar volumen y Encendido.
- Cuando aparezca el logotipo del dispositivo, suelta el botón Encendido y sigue pulsando Bajar volumen.
- Si ves Modo Seguro en la esquina inferior izquierda tras el reinicio del dispositivo, el Modo Seguro está activado; de lo contrario, deberás repetir el proceso. de aquí.
Después de entrar en el modo seguro, aparecerá la palabra "modo seguro" en la esquina inferior izquierda de la pantalla del teléfono. Ahora prueba con la cámara. Si funciona, sabrás que es una App de terceros en tu teléfono la que causa esto. Tendrás que eliminar esas Apps una tras otra.
Si sigue sin funcionar, puede que tengas que plantearte sustituir la cámara, ya que podría tratarse de un problema de hardware. Como iFixit aún no tiene una guía para esto, utiliza algo como este vídeo. Hay cámaras de repuesto en muchas tiendas online. Todo lo que venga después es una reparación a nivel de placa y necesitarás los esquemas, la disposición de los componentes, etc., así como un equipo de pruebas para arreglarlo.
Mientras trabajas con el teléfono, haz muchas fotos. Cuando hayas terminado, haz esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga un dispositivo con los mismos problemas que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
También me sucedió lo mismo después de hacerle un reballing a mi poco x3 pro
- de Guy R Lopez
