E1 error appeared?not able to use it
E1 error coming
Es esta una buena pregunta?
I found this:
The E1 error code on your Gourmia air fryer usually indicates a problem with the temperature sensor. This error code is often triggered when the air fryer's temperature sensor fails to detect a temperature reading.
Here are a few troubleshooting steps you can try to resolve the E1 error code on your Gourmia air fryer:
If all of this does not solve it, then a repair is required and the sensor need to be replaced.
Fue útil esta respuesta?
Where the temperature probe its located
Hi! Please visit this website for images and further details: https://www.diynot.com/diy/threads/air-f...
The E1 Error Code Is Still Flashing & The A/Fryer Will Not Switch On ??
Ultimas 24 horas: 17
Ultimos 7 días: 87
Ultimos 30 días: 434
Todo El Tiempo: 1,057
