Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
El Acer Extensa 2509 cuenta con un procesador Intel Celeron N2930 con gráficos Intel HD.
Why is my internal hard drive is not accepted by my pc
Why is my pc doesn't wanna accept my hard drive
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Please provide more information- such as what type of hard drive are you adding? I know that there are certain bios/EFI settings for some laptops and you may need to verify compatibility. What is the operating system? What have you tried so far? Can you check a different drive?
- de Compartir
Agregar un comentario
2 Respuestas
First check in Disk Management if the drive shows up if it does but has no letter, assign one or initialize it if it’s new. If it’s not listed, reseat the SATA and power cables or try a different port to rule out connection issues. If it still doesn’t appear, the drive itself may be faulty or incompatible, so testing it on another PC is the quickest way to confirm.
Fue útil esta respuesta?
Puntuación 0
Well you can try the following:
Check Physical Connections
Check if BIOS/UEFI Detects the Drive
Check Disk Management in Windows
Check for Driver Issues
Puntuación 0
Añadir tu respuesta
Nkocie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 28
Todo El Tiempo: 284
