Is there anyway to service the OEM fan bearing?
Long story short, the fan bearing for the fan is not stable. I've taken apart the computer and disconnected the battery and the fan.
Upon inspection, dust was removed and compressed air was shot into the fan to monitor the fan's ability to spin.
What was noticed was that the fan would begin losing stability as the RPMs increased, leading to believe the bearing was bad. Furthermore, applying light pressure on the sides of the fan showed that the fan was tilting about it's bearing.
At slower speeds, the fan works OK, but as it speeds up, it begins to smack into the fan's casing at higher speeds - causing an audible noise.
Is there any possible way to service the bearing? New part should be in order later, but in the meantime I can't bring my laptop to my school because the noise is so loud and disturbing.
Es esta una buena pregunta?
