Fuel light not lighting on dash panel
No fuel warning on dash panel
Es esta una buena pregunta?
Greetings David,
When you first turn the key during the initial power on light test does the light attempt to light at all?
Try these steps.
Report back the result and I can dig you up some further instructions. The Hondas from memory are usually designed to light up if less then 2 gallons of gas.
Hope this helps!!
Cheers
Monte
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 6
