Saltar al contenido principal
El Xiaomi Redmi 9C es un teléfono inteligente económico de Xiaomi lanzado en junio de 2020. Tiene una pantalla LCD IPS de 6.53", una cámara principal de 13 MP, una batería de 5000 mAh y funciona con un Helio G35.
Preguntas 20 Ver todo
My mobile is not charging
Hello, my mobile is not charging
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
@redmi938979 verify that your phone is a Xiaomi Redmi 9C
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
@redmi938979 not charging and not holding a charge are two different things. It will be helpful if you give us more details. We will need to know exactly what it does when you try to charge it. In the meantime start off by testing the easy things.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Fue útil esta respuesta?
Puntuación 1
هاتفي لا يشحن
Puntuación 0
Añadir tu respuesta
Redmi 9 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 43
Todo El Tiempo: 334
