Saltar al contenido principal
Lanzado el 21 de julio de 2011. Procesador Core i5 o Core i7. Rayo. Esta unidad también se utiliza para ejecutar la configuración de Mac mini Server.
Stuck in loop boot and will only safe boot
First I tried to restore using mac OS recovery which did not complete the install. Due to posable expired certificate issue.
So I download High Sierra and made a bootable installer. Formatted the SSD and ran the installation, this did not complete the installation process. But then enters a boot loop, boot runs then restarts to about 3/4 off the grey install screen, then reboots again.
Then on the start of a reboot pressed the shift and managed to complete the installation process in safe mode.
Now it is continuously still stuck in loop boot. It starts to 3/4 grey startup screen and restart again.
But you can force it into safe mode. Also now the start chime now has stoped working.
I have tried many times now and have lost my way forward.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
To get around the expired Cert you'll need to use a second Mac system to download the OS installer file and then setup a USB thumb drive as a bootable OS installer (don't forget to first format the USB drive to GUID-Journaled) Goto this cute to get the OS file How to download and install macOS then follow this guide Create a bootable installer for macOS.
See if that gets you going, good luck! You may need a new drive.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
john estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 147
