Saltar al contenido principal
El Xbox original es el primer sistema de videojuegos de Microsoft. Tiene una carcasa negra fácilmente identificable con 'XBOX' blasonado en la parte superior y frontal. La reparación es fácil con herramientas comunes.
Power supply flashes red and green, then reset button pops out
Recently, my xbox power cable (the one with the RESET and TEST buttons) has not been cooperating with me. I do the safety method every time I use it (press TEST, RESET button should pop out, then press RESET), but recently whenever I press in the RESET button, the indicator light flashes between red and green for a bit, and then the RESET button pops back up. How do I fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
So either the gfi brick (power cord) has ceased being able to do it's job or (and this is equally likely/possible) it's doing it's job correctly and your actual power supply has developed a dead short. The version 1.0 xbox had a Foxcon power supply which had a design oversight/flaw. The solder joints on the power port could break and cause a dead short which in turn "could" cause a fire. So xbox release free of charge to all customers that GFI enable power cord. It's job is to trip and cut power if it detects a short in the power supply, this is to prevent a possible fire.
This is a potentially serious matter for which there isn't likely an "easy" fix. If you want you could try a different "known working" gfi power cord. If it still happens then the fault will definitely be the internal power supply. That would be the easiest place to start. I strongly advise against messing with the internals of either the gfi or the consoles power supply unless you know what you are doing/dealing with.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Lappy4861 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 112
