Saltar al contenido principal
El Galaxy Watch Active2 es un reloj inteligente de Samsung Electronics. Su número de modelo es SM-R825, SM-R830 o SM-R835 y se lanzó en agosto de 2019.
Preguntas 20 Ver todo
My watch screen opened up
I went swimming and i put the watch next to the pool but it fell into the pool, the screen popped out and when i let it dry it still doesnt turn on what can i do to fix it or is it gone forever?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Depending on how it "opened up". If the screen separated completely with the watch I suggest you replace the watch completely. But even so if it slightly opened and water entered the system repairing would be of no use
Hope it helps
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
It opened up but still attached with little droplets of water which i managed 2 remove
- de
Try charging it (make sure it is dry) if it turns on you are good to go(if the screen can easily stay there with no movement). If it is still not sticking back , I suggest opening it up, gently apply heat to the screen to make the adhesive sticky and try putting it back. If it doesn't work I suggest you get some of that adhesive (when I get the name I will inform you) and try putting it on.
- de
Añadir tu respuesta
I5m4il7 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 127
