¿Se puede arreglar un pixel que se mojó en el mar?
Hola entre al mar a nadar y se me olvidó retirarme el reloj y no prende, hay forma de repararlo?
Es esta una buena pregunta?
@franco3668 you need to treat it just like you would treat any other water immersed device. First you need to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your watch using Google Pixel Watch . Remove the motherboard and clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide Even so it was written for an Apple iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your watch and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Translation
@franco3668 tienes que tratarlo igual que tratarías cualquier otro dispositivo sumergido en agua. En primer lugar, debes dejar de intentar cargar, sincronizar o utilizar el teléfono. Esto puede empeorar la situación y dañar aún más el teléfono.
Lo siguiente es limpiarlo. Desmonta tu reloj siguiendo Google Pixel Watch . Retira la placa base y limpia toda la placa, conectores y todo con alcohol isopropílico +90%. Sigue [guía|5825|esta guía] Aunque fue escrita para un iPhone 3G de Apple, todos los puntos siguen siendo pertinentes para tu teléfono. Mientras limpias la placa, comprueba si hay daños evidentes, como componentes quemados o que faltan, etc. No puedo insistir lo suficiente en la importancia de una buena limpieza, así que hazlo una y otra vez sustituyendo el alcohol después de cada limpieza.
Cuando esté bien limpia, sustituye la pila. Todos estos pasos son para evitar el fallo retardado causado por la corrosión. Lo mejor sería limpiarla con un limpiador ultrasónico, pero si no tienes acceso a uno, esto al menos te ayudará. Una vez hecho todo esto, vuelve a montar tu reloj y evalúalo de nuevo. Hasta que no se limpie, todo será sólo una suposición. Incluso con todo esto, los daños por agua sólo tienen una pequeña posibilidad de repararse completamente, pero al menos puedes intentarlo.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 14
