Porque no carga y no prende mi A10 s
Ya no carga se keda solo en 0
Es esta una buena pregunta?
First you want to check your charger. Make sure it has the proper voltages. Check the charging cable to make sure that the connectors are not bend etc. After that, check the charging port. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. It is possible that this is a battery issue but it can also be caused by the charging board.
I suggest you replace the charging board as well as the battery. You can check places like Amazon etc. for a replacement of it. Since iFixit does not yet have a guide for that, use something like this video (only up to 1:30min) as your guide. It is not a terribly complicated job. You can do it.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://es.ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Primero debes comprobar tu cargador. Asegúrate de que tiene los voltajes adecuados. Comprueba el cable de carga para asegurarte de que los conectores no están doblados, etc. Después, comprueba el puerto de carga. Asegúrate de que no hay corrosión, residuos, etc. que impidan que funcione. Límpialo de restos, etc., utiliza unas bocanadas de aire para limpiarlo. Si nada de esto funciona, coge un amperímetro y comprueba si tu portátil consume algún amperaje del cargador. Después, comprueba si la placa base recibe alimentación. Para ello, por supuesto, tienes que abrirla. Es posible que se trate de un problema de la batería, pero también puede deberse a la placa de carga.
Te sugiero que sustituyas tanto la placa de carga como la batería. Puedes buscar en sitios como Amazon, etc. para sustituirla. Como iFixit aún no tiene una guía para ello, utiliza algo como este vídeo (sólo hasta 1:30min) como guía. No es un trabajo terriblemente complicado. Tú puedes hacerlo.
Mientras trabajas con el teléfono, haz muchas fotos. Cuando hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es hacer la guerra a la entropía!
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 24
Todo El Tiempo: 68
