Saltar al contenido principal
Lanzada en noviembre de 2020, la MacBook Air de 13" cuenta con el SoC M1 basado en Arm de Apple con una CPU de 8 núcleos y una GPU de hasta 8 núcleos. (Modelo A2337/EMC 3598 con dos puertos Thunderbolt 3)
Preguntas 20 Ver todo
M1 MacBook Air speakers have distortion/rattling
My M1 MacBook Air speakers have strong distortion/rattling, most noticeable when listening to piano music. The distortion is present even at 25% volume.
I tried buying a used set of speakers on eBay, but they had the exact same distortion. My best guess is that the used speakers I bought on eBay were also damaged, but is it possible that my audio board is the problem? There is no distortion when using headphones, so it seems unlikely that the audio board is at fault, but I want to be sure that it's good before I buy another set of speakers.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
yes it sound like it is the speakers but I would first check that the speakers where properly installed in the first place as it can be easy to not replace them quite right.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
My speakers were original, installed from the factory by Apple. They worked great for a while, but then they started having strong distortion.
Then I installed replacement speakers by myself, and they had the exact same distortion as the original speakers. I installed them with double-sided tape that was exactly the same width as Apple's adhesive, applied in exactly the same spot, and the speakers were perfectly centered in the cutout where they belong.
- de
Añadir tu respuesta
Daniel Korzhenevich estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 133
