Mi teléfono se apaga y se reinicia solo
Mi celular se apaga solo y se reinicia
Es esta una buena pregunta?
@eliecer18253 that is usually caused by either a power issue or a software issue. I would start by starting the phone in safe mode. If it stays on, then you know that the issue is caused by a 3td party App . you will have to uninstall those one by one until you find the one that causes this. To start your phone in safe mode: When the phone is turned on, long press the volume down key to enter the safe mode. After entering the safe mode, the word "safe mode" will appear in the lower left corner of the phone screen.from here To get out of safe mode just restart your phone
If sae mode does not work, replace the battery and check the flex cables from the charging board to the main board. Make sure that it is properly seated. Check your phone for corrosion on any of the connectors and check for torn flex cables.see if that makes a difference. Since iFixit does not yet have a guide for this, use something like this video
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@eliecer18253 eso suele deberse a un problema de alimentación o de software. Yo empezaría iniciando el teléfono en modo seguro. Si se queda encendido, entonces sabrás que el problema está causado por una 3td party App . tendrás que desinstalarlas una a una hasta que encuentres la que lo causa. Para iniciar el teléfono en modo seguro: Cuando el teléfono esté encendido, pulsa prolongadamente la tecla de bajar volumen para entrar en modo seguro. Tras entrar en el modo seguro, aparecerá la palabra "modo seguro" en la esquina inferior izquierda de la pantalla del teléfono.de aquí Para salir del modo seguro sólo tienes que reiniciar el teléfono
Si el modo sae no funciona, sustituye la batería y comprueba los cables flexibles que van de la placa de carga a la placa principal. Asegúrate de que están bien asentados. Comprueba si hay corrosión en alguno de los conectores de tu teléfono y comprueba si hay cables flex rotos.a ver si eso marca la diferencia. Como iFixit aún no tiene una guía para esto, utiliza algo como este vídeo.
Mientras trabajas en el teléfono, haz muchas fotos. Cuando hayas terminado, haz esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 18
Todo El Tiempo: 32
