Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un controlador con forma de guitarra para Guitar Hero III de la franquicia de videojuegos Guitar Hero.
Green + red + yellow cause strum
Hi, having an issue where pressing the first three frets at once causes a downstrum. When I hold these frets, I can still strum up after the first downstrum has happened, but strumming down has no effect.
I have already resoldered the neck connector pins and have even gone as far as to completely unsolder the entire 14-pin strum bar connector from the "main" board, the one with the Xbox button. As far as I can tell, none of the connections on that 14-pin board are shorted to the one next to it and I've run out of ideas.
What could I do next to try and pinpoint the problem? Has anyone fixed an issue like this on their controller?
Es esta una buena pregunta?
Puntuación 0
1 comentario
Issue actually fixed here: https://www.reddit.com/r/GuitarHero/comm...
OP here soldered signal diodes between certain connections to resolve the issue.
What I posted before did not work.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Fue útil esta respuesta?
Puntuación 0
Ended up still being an issue with the neck connections being wired incorrectly. According to Reddit user DeBlakee, the guitar uses a 4 x 4 matrix for inputs, which explains how the neck can affect the strum bar. Link to the Reddit comment here.
Puntuación 0
Añadir tu respuesta
Martin V estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 368
