Machine Agitates but won't spin
the machine will not spin but agitates and drains. I changed the coupler and the clutch but it still won't spin. The motor runs and I can hear the change when I change speeds but the tub will not spin. Also, the tub is very hard to spin manually. Is this the transmission or the tub causing this?
Es esta una buena pregunta?
6 comentarios
Hi @njbob,
What is the model number of the washer?
- de jayeff
Hi - it is 110.20952992
- de njbob
@njbob
Can you manually rotate the tub in both directions or only the one way?
- de jayeff
I can spin it both directions - tight but it moves
- de njbob
@njbob
Check the agitator dogs are OK.
They prevent the agitator from rotating in both directions as it should only rotate in the one direction
- de jayeff
Mostrar 1 comentario más
