Saltar al contenido principal
Esta es una cámara de apuntar y disparar creada por Canon en 2011.
Preguntas 12 Ver todo
Fixes for "Wrong Flash Position, Restart the camera"
I keep getting this error and It would be too expensive to send to canon. What might be malfunctioning here?
P.S. I opened the camera and cleaned it's gears on the flash and it doesn't still seem to work
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@zhyctnani seems to be a common issue with this camera try this "I managed to fix it myself by first turning off the camera and fully pushing the flash all the way down. That did not yet solve the problem. Then I did a reset as described earlier in this thread. Again, no change. Finally, I used a fingernail to pull the flash mechanism all the way up, again while the camera was off. I then turned the camera on and turned it off again, and it retracted. Now it extends and retracts as expected, and with no more errors." from here while we keep looking for a viable solution.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Zhyct Nani estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 36
Ultimos 30 días: 85
Todo El Tiempo: 1,228
