Which cable is which?
Green with what? Red with what? What are the other cables near the green and red ones? Ground???
Es esta una buena pregunta?
@silviurec you should have two set of wires. One set Red/Copper and the other set Green/Copper. Red wire is Right Speaker + and Coper is Right Speaker Gnd. Green wire is Left speaker + and copper is Left speaker ground.This is where you need to connect the wires to:
Left = Tip
Right = Ring
Ground = Sleeve Both of the Copper wires get soldered on that pin
Something that looks like this will work for your headphones.
img from here
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 48
