Saltar al contenido principal
Disponible. Publicado el 7 de marzo de 2019 LCD IPS - 6,26 pulgadas Resolución - 720 x 1520 píxeles Sistema operativo: Android 8.1 (Oreo), EMUI 8.2 Conjunto de chips: Qualcomm SDM450 Snapdragon 450 (14 nm)
Preguntas 20 Ver todo
Water damaged phone need to fix
So I dropped my phone in water and has been damaged, it won't turn on or anything, so I opened it up dried as much as I could. I then cleaned any corrosion using isopropyl alcohol from the connection ports. I put everything together and now when I plug in my charger to the phone it keeps vibrating every second. If I disconnect my battery the red charging LED comes up, but not when I reconnect the battery. Any idea what the issue could be?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Salut s'il vous plaît montre comment faire pour à résoudre le caméra 📷
- de
@stanleysylvain If your camera is a damaged because of water, then the answer is the same as my original answer. If you have other issues with your camera, then you have to give us more details.
Translate
Si votre appareil photo a été endommagé par l'eau, la réponse est la même que celle que j'ai donnée initialement. Si vous avez d'autres problèmes avec votre appareil photo, vous devez nous donner plus de détails.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@sajidtalati you said you cleaned any corrosion "from the connection ports" but you are not saying if you cleaned all the boards. You do need to remove the EMI shields from your boards. If you do not remove the shields, you are not cleaning the board.
Once you got the shields and the boards removed, clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
In your case, I would probably not clean the sub_board (charging board) but I would replace it. The boards are relatively inexpensive and by replacing it, you eliminate any issues with that. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board properly and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
You also need to keep in mind that it is possible that your display has been shorted out. You may have to replace the display assembly as well.
Sustitución de la Placa de Carga del Huawei Y7 2019
Imagen de iPhone
Guía
Reparación de los daños en un iPhone debido a la entrada de líquidos
Dificultad:
Difícil
1 - 2 hours
Imagen de Huawei Y7 2019 Placa de Carga
Guía
Dificultad:
Fácil
10 minutes
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Sajid Talati estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 187
