Como cambio la cámara frontal
Mi celular no muestra imagen cuando enciendo la cámara frontal
Es esta una buena pregunta?
try to enter the Samsung Hardware Diagnostic Test Menu by dialing *#0*# There is a test menu for the cameras and see if that works. You also want to try to start your phone in safe mode to rule out a 3rd part App as the cause for that. Here are the directions from Samsung
Step 1. Turn the device off by holding the Power button until the option to Power Off appears on the screen. Tap Power off.
Step 2. Press and hold the Power and the Volume Down buttons at the same time, to turn the device on. When you see the Samsung logo appear on the screen, you can let go of the Power button while the device boots up. Make sure to keep holding the Volume Down button.
Step 3. If done correctly, 'Safe Mode' will display on the bottom left corner of the screen. If 'Safe Mode' does not appear, repeat the steps above.
Step 4. Once you're in Safe Mode, try your camera and see if it works. If so, it is a bad 3rd part App that is causing this. You will have to delete those Apps.
If none of this works, you may have a bad camera. Since iFixit does not have a guide for this, use the one from here Replacement cameras are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
intenta entrar en el menú de prueba de diagnóstico de hardware de Samsung marcando #0# Hay un menú de prueba para las cámaras y ver si eso funciona. Usted también quiere tratar de iniciar el teléfono en modo seguro para descartar una App 3 ª parte como la causa de que. Aquí están las instrucciones de Samsung
Paso 1. Apague el dispositivo manteniendo pulsado el botón de encendido hasta que aparezca la opción Apagar en la pantalla. Pulsa en Apagar.
Paso 2. Mantenga pulsados los botones Encendido y Bajar volumen al mismo tiempo para encender el dispositivo. Cuando veas aparecer el logotipo de Samsung en la pantalla, puedes soltar el botón de encendido mientras el dispositivo se inicia. Asegúrate de mantener pulsado el botón de bajar el volumen.
Paso 3. Si se hace correctamente, aparecerá "Modo Seguro" en la esquina inferior izquierda de la pantalla. Si el "Modo Seguro" no aparece, repita los pasos anteriores.
Paso 4. Una vez que esté en Modo Seguro, pruebe su cámara y vea si funciona. Si es así, es una mala App de 3ª parte la que está causando esto. Tendrás que borrar esas Apps.
Si nada de esto funciona, es posible que tenga una mala cámara. Desde iFixit no tiene una guía para esto, utilice el de aquí Hay cámaras de repuesto disponibles en muchas tiendas online.
Mientras trabajas en tu teléfono, haz muchas fotos. Una vez que haya terminado con él, tomar esas fotos y crear una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 27
