Saltar al contenido principal
El teléfono viene con una pantalla táctil de 6,50 pulgadas que ofrece una resolución de 720x1600 píxeles con una densidad de píxeles de 269 píxeles por pulgada (ppi) y una relación de aspecto de 20:9. Oppo A53 2020 funciona con un procesador Qualcomm Snapdragon 460 de ocho núcleos a 1,8 GHz. Viene con 4 GB de RAM.
¿Mi teléfono se moho y no prende?
Mi teléfono tardo un rato en agua y ya no prende
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
En la mayoria de casos el daño es irreparable, debido adiversos modulos dañados por la bateria, acude a sun servicio tecnico de telefonia movil, que lo evaluen si es reparable.
Fue útil esta respuesta?
Puntuación 1
@torresjime25706 I most certainly agree with the great answer given by my esteemed colleague @carloslopez1970 I am just a bit more stubborn and like to try to get things back to life. For that reason, I suggest this.
For now you need to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The very first step would be to disassemble your phone. Since iFixit does not yet have a guide for that, use something like this video or the guides from here Slightly different model (53S) but steps are pretty much identical.
Remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors, assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave your phone to dry. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned After teh cleaning, Do not forget to replace the battery. In most of these case for the phones that have a sub_board (charging board) I prefer to not clean the board but to replace it. Costs are minimal and a replacement will always rule out a damaged part, should the cleaning not yield any results. Replacing the battery is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your boards and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@torresjime25706 Sin duda estoy de acuerdo con la gran respuesta que ha dado mi estimado colega @carloslopez1970 Yo es que soy un poco más cabezón y me gusta intentar que las cosas vuelvan a la vida. Por esa razón, te sugiero lo siguiente.
Por ahora tienes que dejar de seguir tratando de cargar, sincronizar o utilizar el teléfono de otra manera. Esto puede empeorar la situación y dañar aún más el teléfono.
El primer paso sería desmontar el teléfono. Dado que iFixit aún no tiene una guía para eso, use algo como este video o las guías desde aquí Modelo ligeramente diferente (53S) pero los pasos son más o menos idénticos.
Quitar la placa principal y la placa de carga. Usted tendrá que quitar todos los escudos EMI. Si no quita los escudos, no está limpiando la placa.
Mire de cerca todos los componentes y conectores, evalúe los daños. Busque corrosión importante, evalúe los pines en los conectores, etc,. Revise todos los conectores y los extremos de los cables. . Una vez que haya limpiado toda la suciedad, utilice alcohol isopropílico al 90% y limpie las piezas un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero todos los pasos siguen siendo pertinentes a su teléfono también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza.
No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en las zonas que causarán problemas más adelante. No es necesario dejar secar el teléfono. El alcohol isopropílico en mayor concentración se evaporará rápidamente y disipará el agua.
Lo importante aquí es la limpieza. Por supuesto, lo mejor es limpiarlo con ultrasonidos Después de la limpieza, no se olvide de cambiar la batería. En la mayoria de estos casos para los telefonos que tienen una sub_placa (placa de carga) prefiero no limpiar la placa sino reemplazarla. Los costos son mínimos y un reemplazo siempre descartar una parte dañada, en caso de que la limpieza no da ningún resultado. Sustituir la batería es una obligación y no una opción. Fallará si no te ocupas de ella ahora.
Después, vuelva a montar el teléfono y evalúe de nuevo. Mientras no hayas limpiado las placas y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño.
Puntuación 0
Añadir tu respuesta
Torres Jiménez Atónito estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 90
