Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Xiaomi Redmi 9C es un teléfono inteligente económico de Xiaomi lanzado en junio de 2020. Tiene una pantalla LCD IPS de 6.53", una cámara principal de 13 MP, una batería de 5000 mAh y funciona con un Helio G35.
¿ Por qué mi redmi . No enciende pero si carga .?
Mi redmi se mojo y la pantalla se me rompio . Lo seque cambie la pantalla pero conecto el cargador . Cargo . Quedó al 100% pero no enciende ni arranca .?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@davidriver99943 drying the circuit boards may not be enough. You will have to clean it. For now you need to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
Te next step I would take is to disassemble your phone. Use this guide as well as the one for the charging board from here Take a close look at all components and connectors. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned. I would not clean the charging board, but I would replace it. This is because it is relatively inexpensive and could be the issue with your phone. By changing it, you eliminate it as a cause for the power issue. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@davidriver99943 secar los circuitos puede no ser suficiente. Tendrás que limpiarlo. Por ahora es necesario dejar de continuar para tratar de cargar, sincronizar o utilizar el teléfono de otra manera. Esto potencialmente puede hacer una mala situación worse.This puede dañar aún más su teléfono.
El siguiente paso es desmontar el teléfono. Utiliza esta guía así como la de la placa de carga desde aquí Echa un vistazo de cerca a todos los componentes y conectores. Busque corrosión importante, evalúe los pines en los conectores, etc,. Echa un vistazo a todos los conectores, así como los extremos de los cables. Usted tendrá que quitar todos los escudos EMI. Si no quita los blindajes, no está limpiando la placa. Una vez que hayas limpiado cualquier contaminación, utiliza alcohol isopropílico 90%+ y limpia tus partes un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero sigue siendo pertinente para su teléfono también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza. No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en las zonas que causarán problemas más adelante. No es necesario dejar secar durante un día. El alcohol isopropílico en mayor concentración se evaporará rápidamente y disipará el agua. Lo importante aquí es la limpieza. Por supuesto, lo mejor es que lo limpie un profesional. Yo no limpiaría la placa de carga, pero la sustituiría. Esto se debe a que es relativamente barata y podría ser el problema con su teléfono. Al cambiarla, se elimina como una causa para el problema de energía. No te olvides de cambiar la batería. Esto es un deber y no una opción. Fallará si no te ocupas de ella ahora. Después de eso, vuelva a montar el teléfono y vuelva a evaluar. Mientras no hayas limpiado la placa y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
David Rivera estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 4
Todo El Tiempo: 732
