Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzado en septiembre de 2016. Identificado por el modelo No. SM-G610
La antena WiFi no funciona
No me conecta a redes WiFi a distancia
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
@mauricio47582 find out if your BLuetooth works. Next you want to try a start in safe mode and see if that helps with your issues. If it does, you have a bad App on your phone and will have to remove it. Check on here how to enter safe mode.
If that did not work, ty to start in Recovery mode. Here you can resolve issues that are related to software. To enter into recovery mode, use the info from this site
The last software step to try is to do a factory reset. You will lose all of your files, contacts, pictures,etc. So make sure that you have a backup of all of those. You will also need your google password etc. that you used for setting up this phone. It will ask you for this on restart. The info on how to do that can be found right here
After that you can start focusing on the hardware. Follow the Samsung flowchart for that
and use the search function on your PDF reader on this document to find the location for the components that need to be checked.
Since iFixit does not yet have a guide for this, use something like this video
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@mauricio47582 averigua si tu BLuetooth funciona. A continuación, desea probar un arranque en modo seguro y ver si eso ayuda con sus problemas. Si lo hace, usted tiene una mala aplicación en su teléfono y tendrá que quitarlo. Compruebe aquí cómo entrar en modo seguro.
Si eso no funcionó, ty para iniciar en modo de recuperación. Aquí puede resolver los problemas que están relacionados con el software. Para entrar en modo recuperación, usa la información de este sitio.
El último paso de software a intentar es hacer un restablecimiento de fábrica. Perderás todos tus archivos, contactos, fotos, etc. Así que asegúrate de tener una copia de seguridad de todos ellos. También necesitará su contraseña de Google, etc que utilizó para configurar este teléfono. Se le pedirá esto en el reinicio. La información sobre cómo hacerlo se puede encontrar justo aquí
Después de que usted puede comenzar a centrarse en el hardware. Siga el diagrama de flujo de Samsung para que
Imagen
y utilizar la función de búsqueda en su lector de PDF en este documento Component Layout para encontrar la ubicación de los componentes que necesitan ser revisados.
Como iFixit aún no tiene una guía para esto, usa algo como este vídeo.
Mientras trabajas en el teléfono, haz muchas fotos. Una vez que hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Mauricio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 175
