Cómo puedo recuperar la información que está en el celular?
Le cayó agua salada y dejo de funcionar
Es esta una buena pregunta?
@davidotero3423 this will require some extra steps since we are dealing with Salt Water.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Use these guides Huawei P20 to disassemble your phone. Remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors to assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Now to clean the gross contamination, use some distilled water and wash all the parts with that and a soft brush. Yes, it is okay to submerge those parts in distilled water, with the exception to the display. Rinse all the residual salt and other debris off. Once you got any gross contamination cleaned, use 96%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for any time. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned. In the case of this phone, I would replace the charging board. It is not expensive and readily available at many places. That way you can eliminate that this board has residual water damage etc. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate.
For as long as you have not cleaned your boards and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Repair is War on Entropy.
Translation
@davidotero3423 esto requerirá algunos pasos adicionales ya que se trata de Agua Salada.
Por ahora, debes dejar de seguir intentando cargar, sincronizar o utilizar de cualquier otra forma tu teléfono. Esto potencialmente puede empeorar una mala situación. Esto puede dañar aún más su teléfono.
El primer paso que tomaría es desmontar el teléfono. Utilice estas guías Huawei P20 para desmontar el teléfono. Retire la placa principal y la placa de carga. Usted tendrá que quitar todos los escudos EMI. Si no retiras los escudos, no estarás limpiando la placa.
Echa un vistazo de cerca a todos los componentes y conectores para evaluar los daños. Busque corrosión importante, evalúe los pines en los conectores, etc,. Echa un vistazo a todos los conectores, así como los extremos de los cables. Ahora para limpiar la contaminación gruesa, use un poco de agua destilada y lave todas las partes con eso y un cepillo suave. Sí, está bien sumergir las piezas en agua destilada, con la excepción de la pantalla. Enjuague todos los residuos de sal y otros desechos. Una vez que hayas limpiado cualquier contaminación gruesa, utiliza alcohol isopropílico al 96%+ y limpia tus piezas un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero todos los pasos siguen siendo pertinentes para su teléfono también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza.
No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en las zonas que causarán problemas más adelante. No utilice agua potable, si necesita utilizar agua, utilice agua estéril. Tampoco es necesario dejarla secar durante ningún tiempo. El alcohol isopropílico en mayor concentración se evaporará rápidamente y disipará el agua.
Lo importante aquí es la limpieza. Por supuesto, lo mejor sería limpiarlo con ultrasonidos. En el caso de este teléfono, yo cambiaría la placa de carga. No es caro y fácilmente disponible en muchos lugares. De esta manera se puede eliminar que esta placa tiene daños residuales de agua, etc. No te olvides de cambiar la batería. Esto es una necesidad y no una opción. Fallará si no te ocupas de ella ahora. Después de eso, vuelva a montar su teléfono y vuelva a evaluar.
Mientras no hayas limpiado las placas y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño.
La reparación es la guerra a la entropía.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 9
