Dice que el teléfono se está sobrecalentando
Se apaga la pantalla y se cierran las aplicaciones aparte que se apaga completamente cuando dice que esta sobrecalentado
Es esta una buena pregunta?
puede ser el modulo del wifi algunos telefonos se calientan mucho por eso, prueba a desinstalar aplicaciones
Fue útil esta respuesta?
@milenisrangel first start your phone in safe mode. If it doesn't give you the overheat message in sage mode, your phones issues are related to a bad 3rd part App on your phone. you will have to install them one by one to find the one that causes it. To get your phone in safe mode you need to:
Step 1. Turn the device off by holding the Power button until the option to Power Off appears on the screen. Tap Power off.
Step 2. Press and hold the Power and the Volume Down ******buttons at the same time, to turn the device on. When you see the Samsung logo appear on the screen, you can let go of the Power button while the device boots up. Make sure to keep holding the Volume Down button.
Step 3. If done correctly, 'Safe Mode' will display on the bottom left corner of the screen. If 'Safe Mode' does not appear, repeat the steps above.
Step 4. Once you're in Safe Mode, you can remove the third-party app that is causing issues on your phone. from here
If that does not work you will have to work on your phone. Your phone has 4 thermistors that can give an erroneous overheating signal. The most common ones to fail are the one on the battery and the one on the charging port. I would replace those parts. Since iFixit does not yet have a guide for those use the ones from herefrom here and the one from here Those guides are in French but your browser should have no problems translating those. Parts are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@milenisrangel primero iniciar el teléfono en modo seguro. Si no le da el mensaje de sobrecalentamiento en el modo de sabio, sus teléfonos problemas están relacionados con un mal 3 ª parte App en su teléfono. usted tendrá que instalar uno por uno para encontrar el que lo causa. Para obtener su teléfono en modo seguro que necesita:
Si eso no funciona tendrás que trabajar en tu teléfono. Tu teléfono tiene 4 termistores que pueden dar una señal errónea de sobrecalentamiento. Los más comunes a fallar son el de la batería y el del puerto de carga. Yo sustituiría esas piezas. Como iFixit todavía no tiene una guía para esos usa las de de aquíde aquí y la de de aquí Esas guías están en francés pero tu navegador no debería tener problemas para traducirlas. Las piezas se pueden conseguir fácilmente en muchas tiendas online.
Mientras trabajas con el teléfono, haz muchas fotos. Una vez que haya terminado con él, tomar esas fotos y crear una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 81
